Results 1 to 10 of 15
Thread: Basic tuning for mild cam? (idle, startup, etc)
    Aug 2012
    Default Basic tuning for mild cam? (idle, startup, etc)
    I have a 2007 5.3, 4l60e with E38 controller. I was burning through a lot of oil and lifters were very noisy on cold startup so I disabled the AFM by changing out all the hardware. While I was there I decided to put in a new cam.
    It's a very mild cam, .522/.529 lift 265/271 Adv on a 114 LSA ( http://www.compcams.com/Company/CC/c...csid=1085&sb=2 )
    I'm looking for a few tips on how to get the idle and startup to act like it used to. Right now the stock idle is just a little too low and it feels choppy, also sets off the misfire code sometimes. If I bump the idle to about 725 it really smooths out. It drives great and fuel trims are only 6-8% max in certain areas after logging them. Are there some basic things I can do to get this thing idling and starting right? The starting is definitely a problem after it warms up. Sometimes it just cranks and doesn't fire after warmed up.
    What is your cam's 0.050" specs...?
    You probably should being idling at 725-750 rpm.
    Have you corrected MAF/VE yet...?
    Make sure it is not ongesting oil thru PCV.
    ~Moderator~
    Aug 2012
    ~Moderator~
    Sorry, my .050 durations are 212/218
    I haven't corrected maf or ve because I don't know how, to be honest. Especially not being used to the VVE tables.
    Do you have a wideband...?
    ~Moderator~
    Aug 2012
    Yes I do. I don't have a bung welded in yet. What should I do after I get it installed?
    After you install the wb, you verify that it works properly.
    Then there are there's some logging to do...
    You would run VE-only (by forcing a MAF DTC) and correct the VE/VVE table.
    Then you would run MAF-only (set the dynamic airflow rpm to zero) and correct the MAF table.
    We're currently working on a method that corrects MAF and calculates VE from it, see this thread, we're not quite ready yet (we're still ironing out a few things): Volunteers-needed-for-E38-E67-Calc-VET-project
    Aug 2012
    Thanks I'll be watching that thread.
    As far as correcting the vve table is there a tutorial for it? I was still getting familiar with the ls1b ve tables...
    See these documents:
    Links for easy reference:
    E38 VVE Setup Guide
    Virtual VE Tutorial
    ( from post #83 of this thread: E38-VVE-Setup-Guide )
    New Member KingChalk's Avatar
    Mar 2017
    I believe richening up the air fuel at idle will help the smoothness as well. And I do agree that it should idle a little higher
    Sent from my iPhone using Tapatalk
    Aug 2012
    I've played around with startup airflow and idles and it seems to be running and starting pretty well. The only thing i noticed is that when I am slowing to a stop, just before I stop completely and it downshifts, I almost feel the truck pull forward under my braking. I don't recall that before. Also, when idling while rolling at very low speed I see the rpm cycling up and down about 300 rpms. Is that normal?
  1. DBW cam idle tuning. Where do i start?
    By hotrod in forum Gen III V8 Specific
    Last Post: July 18th, 2013, 09:46 AM
  2. Looking for mild heads/cam base tune 1999 LS1
    By krwyellowz28 in forum Gen III V8 Specific
    Last Post: May 1st, 2013, 10:04 AM
  3. E40 idle tuning with cam
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: October 25th, 2009, 07:31 AM
  4. Need a basic lesson on idle tune w/cam..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 12:07 PM
  5. cam install basic tune
    Last Post: April 23rd, 2006, 06:31 AM
