Results 1 to 5 of 5
Thread: Any way to soften shifts a little after corvette servo? 2008 4l60e T42
    Aug 2012
    Default Any way to soften shifts a little after corvette servo? 2008 4l60e T42
    2008 4l60e rebuilt with beast sunshell, alto z pack 3-4 clutch pack and Superior shift kit.
    First rebuilt of a trans for myself so I was surprised when all the gears worked after I installed. The ONLY thing I noticed at the time was when warmed up the 1-2 shift would 'shudder' a bit starting at 25% throttle or more. It also shudders when manually shifting into second with load on engine. I had read that the vette servo may help this and was a good upgrade so I bought it and installed it. Shudder is still there but 1-2 if much stiffer (borderline tolerable) and 2-3 got SUPER stiff. I wasn't expecting any change in the 2-3. I figured I'd go back to the stock servo and at the same time I did that I put a new cam in my 5.3. So when I got it all back together I was out with a heavier foot and now with the stock servo I notice the shifts are smooth again (still has the shudder) BUT I now notice a 300-400 flare on the 2-3 under moderate acceleration. I can even see it in the log file as a little curved up ramp on the RPM. Once again, I put the vette servo back in and now the flare is gone but I have very stiff shifts again. (my biggest worry as I lost 3-4 before after 170K and all I can picture is the frictions burning up everytime it flares)
    My question is, is there anything I can do on the tuning side of this while keeping the vette servo? maybe soften/slow down the 1-2 a little AND 2-3 as well? I almost want something right in the middle of the stock servo and the vette servo. Right now I have stock settings in my tune.
    Post your TCM tune file and any log files you have.
    Make sure your ECM tune is not under-reporting VE/MAF and/or TQ.
    The shudder on 1-2 and the flare on 2-3 is a worry (slippage), monitor the color/smell of your ATF on each drive.
    2-3 should not have gotten stiff (hmmm, let me look it up).
    Attach an external pressure gauge (0-300 psi) on the line tap on the side of the case, monitor this as you drive (the GMSM has specs on this).
    When you assembled the clutches/servo did you air test them (blow clean shop air into their apply hole, watch/feel for apply movement)...?
    What band did you use...?
    Aug 2012
    I will get the trans tune up shortly.
    I did pressurize the clutches when I assembled. All engaged and held. I did not test the servo. I replaced band with a stock band from a transtar rebuild kit. The servo pin is the stock pin. I have not verified the band clearance yet. My shift kit didn't come with any shims for it.
    Usually you would use a wider band, for example find band under here: http://www.sonnax.com/landing_pages/gm_4l60e
    Aug 2012
    Here is my t42 read file. All stock
    t42 read stock.ctz
  1. 5.7 Vortec 4L60E Shifts Hard From Park
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 17th, 2014, 04:16 PM
  2. How to soften part throttle shifts: time or pressure?
    Last Post: June 1st, 2014, 02:00 PM
  3. T42 4L60e TCC tuning
    By jpgmtech in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 1st, 2010, 09:13 AM
  4. Corvette Servo part number???
    By ssvolvo in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 4th, 2008, 12:21 AM
  5. E38 with T42 for 4L60E (no ISS)
    By gmh308 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2008, 01:19 PM
