I give up.... I cannot get my idle AFR to go below 16.00!! I have posted me stock tune, my SD tune (for tuning VE), and my SD tune, attempted to correct idle. in the attempt to correct idle I added 60,70,80,85,90% to the 400-1200 rpm cells to try to richen it up in the VE. I added 1g/sec to the minimum idle base vs, coolant temp in the 1200rpm and under cells, and added 2 degrees to the base idle timing map, in the idle area. Nothing will make this darn thing run rich!! So frustrating
