Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: L99 Camaro 2010 A6 Engine Tuning
  1. #21
    Spikey VE is no good, something is going wrong.
  2. #22
    Mar 2017
    Joecar, I will Post a Map With my BEN tables on it maybe you can view it along with my Tune and apply it and see what happens?
  3. #23
    Yes, you know how to capture a screenshot ( SHIFT-PrtScr... you can use something like Greenshot to help, see getgreenshot.org )
  4. #24
    Mar 2017
    Ok well here is the Logs
  5. #25
    Mar 2017
    here some screen shots
ID:	20922   Click image for larger version.
ID:	20923   Click image for larger version.
ID:	20924   Click image for larger version.
  6. #26
    On MAP A "BEN1_E38" goto map properties, and do this:
    - on Data tab set Precision to 3;
    - On Column tab checkmark Show Units (to show MAP units).
    Save map properties.
    Looks like you did not apply the transient filter.
    Goto PIDs tab, on MAP pid go rightclick->Metric (may already be).
    Also see this, it makes screenshots much easier:
    getgreenshot.org
    https://www.youtube.com/watch?v=m9MTh2x8eh8
  7. #27
    Mar 2017
    getgreenshot.org
    Ok so i adjusted the filters. I re did a log this morning. Now should I take the BEN factors and
    Apply it to the IMTV open table paste with labels and multiply? Then what should be the next step
  8. #28
    Mar 2017
    Quote Originally Posted by StrokedVette385 View Post
    I tried to apply the filter to my logs it won't work says something along the lines of Pid selection. Also what is the VE Imtv closed table for? Do I edit that one as well.
  9. #29
    Before applying the map (with paste-multiply-with-labels), post a sceenshot of it, there are some visual sanity checks we can do.
    Look at what pids the filter uses, and then check to see if those have been logged... keep in mind that any calc pids can be added in at anytime.
  10. #30
    Mar 2017
    ill get back to you later with the screenshot of the Map and with it in tune tool. thanks again
  1. Replies: 0
    Last Post: November 18th, 2013, 01:43 PM
  2. Tuning A 2011 Camaro L99
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 16th, 2011, 04:36 AM
  3. 2010 Camaro L99 Stock - just want to make changes
    By wrek in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2011, 03:34 PM
  4. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    Last Post: December 6th, 2010, 10:33 AM
  5. Tuning a Camaro 2011 A6 L99 questions.
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2010, 12:33 PM
