Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: L99 Camaro 2010 A6 Engine Tuning
  1. #41
    Mar 2017
    Ok, your calc_pid.txt is empty... see attached, rename it to calc_pids.txt and drop it in that folder (see post #38).
    Then:
    drop these pids:
    - E38. AFRATIO_DMA
    - SAE.BARO
    - CALC.BEN_E38
    - CALC.BEN
    - GM.CORRRCALC (I think this might be for oilers)
    - GM.AFR (does not work properly on your ECM)
    - EXT.DYNLAMBDA (if you're not connecting to dyno's serial comms)
    add these pids:
    - SAE.LAMBDA (you already have this)
    - CALC.WO2BEN
    Then, if you run OL:
    - on the map you will now use CALC.WO2BEN instead of CALC.BEN1 or CALC.BEN1_E38.
    If you run CL:
    - on the map you will use CALC.SELBEN (need to also select pids CALC.LTFTBEN, CALC.TRIMMING).
    You are using the wideband's serial connection, right...?
    Yes I'm using wideband serial. I took that file, dropped it in my folder from post #38. SO now i guess i will relog and send you that file back?
  2. #42
    Mar 2017
    Im going to do some logs tomorrow morning. I will save them. I have all the Pics ready to go loaded. you want me to send you my calc pics file then correct? Also does anyone know a good EFI live A6 tuner for the trans? i did dome minor tweaking with a bump in line pressure and shift points MPH markers
  3. #43
    If you had edited your calc_pids.txt file then yes post it, otherwise if it's original then no.
    For the A6 there's a thread about the torque tables.
  1. Replies: 0
    Last Post: November 18th, 2013, 12:43 PM
  2. Tuning A 2011 Camaro L99
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 16th, 2011, 03:36 AM
  3. 2010 Camaro L99 Stock - just want to make changes
    By wrek in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2011, 02:34 PM
  4. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    Last Post: December 6th, 2010, 09:33 AM
  5. Tuning a Camaro 2011 A6 L99 questions.
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2010, 11:33 AM
