Results 1 to 5 of 5
Thread: Logging more than one data stream using Serial Data (Innovate Gauges)?
    May 2014
    Default Logging more than one data stream using Serial Data (Innovate Gauges)?
    Question. I currently log AFR using the serial connection. The gauge I'm using is the Innovate SCG-1 which is a Boost Controller with wideband.
    Can we also simultaneously log Boost/Solenoid duty-cycle along with the AFR? Haven't used LogWorks but the instructions say it's possible. Ofcourse we have the MAP too but just wondering.
    Next question, the data ports in/out on these MTS gauges can be daisy chained and I just ordered a Fuel Pressure Gauge that can be connected to the SCG-1's input port. If the above is possible, can we also log Fuel Pressure using the Serial data port? Would def. be pretty awesome to have just one serial connection and be able to gather many streams of Data.
    FSV2 can log serial data from only 2 daisy chained widebands.
    ~Moderator~
    May 2014
    so I guess we'll have to stick to 0-5volt reference
    In this case, yes.
    May 2014
    Well I had another option to buying separate guages. Buy just the 5V sending units and use a 5V power conditioner and get 0-5V linear output. I have a DashLogic that can get 0-5V inputs too.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  1. Serial Logging with Innovate LC-2, DLG-1, and MTX-D
    By tadams72 in forum External A/D inputs
    Last Post: August 25th, 2019, 11:20 PM
  2. Replies: 1
    Last Post: April 11th, 2011, 08:16 AM
  3. no data stream
    By markhyma in forum EFILive V4
    Last Post: November 6th, 2008, 08:01 PM
  4. Need data stream .xml, have the .ds
    By overclockedpc in forum EFILive V4
    Last Post: October 5th, 2008, 05:38 PM
  5. 95 olds data stream
    By LikeToDrive in forum EFILive V4
    Last Post: November 30th, 2006, 11:48 AM
