Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Reduced power P1516 P2101 truck 88mm TB car OS 07 CTS-v base file etc scaller maybe?
  1. #11
    Quote Originally Posted by 04colyZQ8 View Post
    I now know the hex address of the P1516 in hex.. wink, wink to a mod
    Could I write a CAX for this? likely not write? because Efi doesn't flash the salve?
    Is this a good thing to do, should I try a lower value, now that I know this works? It went full throttle several times now, no issues. ?
    If you know the address/offset of the object and its attributes (format, size) I can help you write a cax file... study the attached example cax file (if you need enumerated values, I'll find another example).
  2. #12
    Feb 2009
    I do know that info, but what good is it, if you can't flash the slave? It's on the second chip.
  3. #13
    Ah, I see.
  1. P1516 and P2101 on boosted E38
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: June 1st, 2017, 11:16 PM
  2. 2007 truck Tq management/ reduced power
    By powermonger in forum Petrol / Gas
    Last Post: February 17th, 2012, 02:23 AM
  3. P1516,P2101 2009 G8 TVS2300 416ci @16lbs
    By 97power in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 5th, 2011, 01:28 PM
  4. P1516 DTC truck goes into limp mode.
    By haulinit in forum Petrol / Gas
    Last Post: May 6th, 2011, 01:47 AM
  5. Car reduced power mode/dies after idling with A/C on for a bit
    By Earl H in forum Custom Operating Systems
    Last Post: June 2nd, 2007, 06:13 AM
