Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: EFI autoCAL ECM flash failure
  1. #11
    Erik, it isn't the first time this has happened to someone with a late model Cummins and unfortunately all the trace files show is the flash completed then dead. We have in the past suspected an issue within the tune but then where this has happened in the past the tune has been used on other vehicle without issue. Nobody ever said Cummins is easy that is for sure.
    Ah dang, so it's really a confusing thing to troubleshoot especially if the SAME file works just fine in another ECM! Thanks for chiming in here.
  2. #12
    Yes, one of the last ones I remember this happening on took out two ECM's, I was sent that file and flashed two of my ECM's here without a problem. That truck then had a third ECM where they put a different tune in and it was fine. Unfortunately one very big downside of not being in 100% control of the flash process like we are on GM gas ECM's, with Cummins (and Bosch) we are constrained by the ECM's rules and often they aren't ideal.
    In all these situations the tunes are also modified outside of EFILive so who knows what has been done.
  3. #13
    Mar 2017
    Had excellent customer support from anarchy diesel.
    Jesse Bubb returned the ecm. Unlocked the ecm, and flashed the tune in to the truck. Put a 2 amp battery charger on just in case that was the issue. Truck is absolutely perfect now. Thanks for all the input guys!
  4. #14
    Glad you got it squared away!
  5. #15
    Apr 2015
    I would look into WaveBPS and a PICOscope. Complimented by vehicle spy and one of their datalink devices you can get pretty granular.
  1. General Programming Failure ($85) $0385 With Autocal
    By Mitco39 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 7th, 2013, 02:09 AM
  2. E38 ecm failure
    By shane in forum Gen IV V8 Specific
    Last Post: February 19th, 2010, 11:19 PM
  3. Flash Failure, No start
    By mcwarren in forum General (Petrol, Gas, Ethanol)
    Last Post: February 20th, 2006, 04:30 PM
  4. ECM Failure
    By a78turbo in forum General (Diesel)
    Last Post: February 6th, 2006, 09:54 AM
