Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Boot Pin Location
  1. #11
    Dec 2015
    Quote Originally Posted by Road View Post
    How ever it is done it is not being shared. There is probably a good reason for not sharing too....
    You should be able to figure it out with that. I know it can be done... If you decide to do it.
    The problem is if people share everything is A. It can open up legal troubles. and B. It can turn the industry into a bunch of wolves fighting over a piece of meat. How would you feel if I could just use a tool to convert your tunes into a .bin? You made this? I made this.
  2. #12
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by Snipesy View Post
    I would just like to know the way to aquire base files. Obviously it's not done with Ktag.
  3. #13
    Dec 2015
    I'm not sure what you're implying. It sounds pretty easy to do if you have a GM subscription and an MDI. Just need to find where the files are cached (shouldn't take too long) and follow my guide here https://forum.efilive.com/showthread...4-Making-a-bin. I'm not gonna sit here and really question if its legal or not, up to lawyers on that one.
    Otherwise... Only other method is to use a separate tool to snoop on network traffic. Intercept the flash as its being transmitted and record it on a computer. Haven't tried that but that would be pretty cool (and allow stealing tunes, which isn't cool).
  4. #14
    Feb 2015
    My guys over at Alientech have it covered now.
  5. #15
    That will make some people happy and annoy others
  6. #16
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    and annoy others
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  7. #17
    Feb 2015
    As you all know we have the Alientech import option for the E86A (the three memory chunks), not sure why the E86B isn't supported by them but when it is we will be able to do the import of those as well.
    Is this still going to be added in?
  8. #18
    I don't know, nobody has submitted an Alientech read from an E86B. It won't be added as a priority though if we do get the files.
  9. #19
    Feb 2015
    Ok I will send some reads to support.
  10. #20
    No worries, but there is LOTS going on right now so like I said it won't be looked at as a priority sorry.
  1. E80 L4 sidi flex fuel pin location 2016 camaro
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 10th, 2017, 02:46 AM
  2. not sure If in right location .
    By 1stock07 in forum Petrol / Gas
    Last Post: March 12th, 2015, 07:36 AM
  3. COS5 N20 PCM pin location??
    By way2much_01 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 21st, 2011, 12:01 PM
  4. location
    By larshep in forum Gen III V8 Specific
    Last Post: November 11th, 2007, 04:05 AM
  5. shift patterns with pin 71 and pin 31 questions
    By Jdperk-86elco in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 23rd, 2006, 03:20 PM
