Results 1 to 9 of 9
Thread: timing at wot while stopped
    Jan 2013
    Default timing at wot while stopped
    I am trying to spool my turbos while foot braking and it seems like the pcm is pulling timing on its own. i have the base spark in gear and high octane table set at about 30 degrees where it needs to be, 2000 rpm and .52-.60 g/cyl and if i ease into the throttle the timing stays high but as soon as i exceed about 30% tps timing starts ramping down to about 12 degrees.
    i have looked all through the tune and cant find anything that would cause this.
    os is COS5 02020005
    i have set abuse management upper rpm to 5000 and speed threshold to 1.
    i disabled axle torque limiting and set max allowed engine torque to 867
    does anyone know how to force more timing in this situation?
    Dec 2014
    Put up a copy of the tune, it could be many thing....
    Jan 2013
    LS1B_TT_80e_0006.ctz
    LS1B_0493.efi
    LS1B_0494.efi
    here is the tune file with a couple short logs
    Dec 2014
    Take a look. I did not work this, just turned off everything I would for a rig like this.
    LS1B_TT_80e_0007.ctz
    Jan 2013
    Ill try it as soon as i get off work today.
    thank you!
    I think it's table B0401.
    Jan 2013
    i used the tune posted and it worked.
    thanks!
    Jan 2013
    That was one of the tables that was changed to make it work, so it very well could have been my problem.
    Dec 2014
    Now work on your fuel and timing.... A BUNCH
  1. unknown timing getting added at WOT
    By hotrod in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 28th, 2011, 07:46 AM
  2. WOT AFR & Timing Tuning
    By blsnelling in forum Gen III V8 Specific
    Last Post: November 2nd, 2010, 07:38 PM
  3. WOT aft and timing
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: May 6th, 2010, 05:43 AM
  4. wot timing?????
    By twinki025 in forum Gen III V8 Specific
    Last Post: October 25th, 2007, 02:29 PM
  5. Loosing 18* of timing at WOT!
    By johnsZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2007, 08:39 AM
