Let's take one step at a time...
attach your calc_pids.txt file here.
Here is my calc_pids file, Before I did a last ditch change to hpt formula.
Use SAE.LAMBDA instead of E67.AFRATIO.
See my reply in your other thread: Were-do-I-find-Ben-factor-LTFT-or-any-ben-factor-I-don-t-see-any-ben-in-my-pids
ok I think I'm close with all these just needs some tweaks guys, here is mi pids, map, and latest calc_pids file. getting a red x through BEN_PLX1_E67 i need to have someone create a ben_ngk_afx_e67 maybe??? confused I still have no clue how to do the LTFT+STFT/200+1
e67_Default_ve_custom.pid
calc_pids2.txt
rename to .map
e67.VE_PLOT2.txt
ok thanks, btw i cant get speedo to show on the scanner? pid is selected and valid??
Yeah pretty sure it's selected? You can see my pids
Maybe it's because it's a manual trans? Factory 07 ctsv manual os, so it should work, trucks speedo works, hp tuners scanner picks up the speed, even showed speed all the way up to 227km/hr (private road of course
