Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Were do I find Ben factor LTFT ?? or any ben factor I don't see any ben in my pids
  1. #11
    Feb 2009
    Ok, so long term trims will come on right away? They usually seem delayed? And using ltft, I should turn on stft, and ltft, then disable the maf, and decel cat protection, as normal.
    Now I still need some kind of map and Ben for ltft verses ve don't I?
    Then I'll need a Ben and map for maf lo, maf hi. After I get the ve dialed in.
    I still want to use my wide band for upper maf, and pe right? And I don't mind logging it all the time just to get a feel for were my trims are heading to.
  2. #12
    Feb 2009
    So you can read the wideband voltage thru the pid GM.ACP...?
    See attached pdf, is this the same as you NGK AFX...?
    If so then see attached calc_pids.txt... you will use the pid CALC.WO2BEN (which uses the pids SAE.LAMBDA and CALC.WB.LAM).
    I need to see the log file, tune file, and some screenshots to see what went wrong.
    See attached calc_pids.txt... the pid CALC.SELBEN does exactly what you want (LTFT's for PT, WB for WOT/PE).
    Are you sure you want LTFT+STFT...? If so, you can add a pid for this and edit the SELBEN pid to use this instead of LTFTBEN (do you want me to do it for you...?)
    BTW: calc_pids.txt file needs at least 2 blank lines at its end.
    http://www.bmotorsports.com/download...ual_REV_06.pdf
    This is mine, sorry I was working a long shift today. Just got off work, thanks for going out of your way, to help Joe I'll buy you a good dinner and beer, if you come to visit Vancouver BC someday!!
    Still reading through all your info, and downloading the updates is slow do to the hotel wifi, I'll be back in Vancouver tomorrow evening, but still I can play around on my note book at the hotel.
    Yeah the GM.ACP was working and was accurate through the a/c port via the voltage offset, I might move it back to the brake booster pcm signal, but I can easily change .acp to the booster later.
    9.0 16.00 .2 "{GM.ACP}*1.4+9.03"
    reading through the manual I think I have this setup correctly? I had "{GM.ACP}*1.4+9" but at 16AFR on the gauge the log didn't match, little bit of match later and it now matched at "{GM.ACP}*1.4+9.03"
    "See attached calc_pids.txt... the pid CALC.SELBEN does exactly what you want (LTFT's for PT, WB for WOT/PE)." perfect that's probably perfect, any advantage or disadvantage to using STFT, as well?
  3. #13
    Feb 2009
    whats the difference between the last two calc_pids you sent? Looks good to me, except:
    *CLC-00-080
    V 0.0 5.0 .2 "{GM.ACP}"
    AFR 9.0 16.0 .2 "{CALC.WB.V}*1.4+9"
    LAM 0.5 1.5 .3 "{CALC.WB.AFR}/14.55"
    EQR 0.5 1.5 .3 "1/{CALC.WB.LAM}"
    should become this:
    *CLC-00-080
    V 0.0 5.0 .1 "{GM.ACP}"
    AFR 9.0 16.0 .2 "{CALC.WB.V}*1.4+9.03"
    LAM 0.5 1.5 .3 "{CALC.WB.AFR}/14.57"
    I think according to my manual, and my earlier voltage offset?
  4. #14
    Feb 2009
    Ok Joe how do these look? I'm getting a few red x through some pids, is that map correct?
  5. #15
    Feb 2009
    here is a screen shot
  6. #16
    Feb 2009
    Does anyone have a E67/E38 maf hi lo, map? I cant copy the lables from the editor to th scanner
  7. #17
    Feb 2009
    my custom map for maf, hi, lo created from hp tuners editor copied col axis, and by hand removed the extra comma on each one..fingers tired now lol:( will these work?
    {B5001} MAF Calibration - E67-Lo_SLben-map.txt
    {B5001} MAF Calibration - E67-hi_SLben-map.txt
  8. #18
    You're in Vancouver huh, good to know. I'm in Seattle and find myself up that way a few times a year. I'll drop you a PM when I'm heading up that way next if you ever want to meet up!
  9. #19
    Quote Originally Posted by 04colyZQ8 View Post
    Trims will come into effect as soon at the CL warmup temperature is reached.
    Yes, enable CL/LTFT/STFT (just like stock), disable the MAF (make sure a MAF DTC shows up immediately), disable DFCO and COTP.
    Yes, use CALC.LTFTBEN for the map (i.e. on the map properties Data tab).
    Yes, use wideband for upper MAF (you will have to enable MAF and disable VE for this) and PE.
    The pid CALC.SELBEN dynamically selects CALC.LTFTBEN during CL (see CALC.TRIMMING) and selects CALC.WO2BEN during non CL.
    should become this:
    *CLC-00-080
    Yes, that's ok, you can edit the calc_pids.txt file.
    I haven't had a chance to look yet, but I will shortly.
  10. #20
    The calc pid with the red X: on this pid go rightclick->More Info to see which other pids need to be selected.
    The other pids with red X: try this: go Info->Validate Pids and see if the red X's go away... otherwise they are the wrong pids for this ECM, or are not supported by this ECM.
  1. Whats a good range of BEN factor for MAF
    By pavetim in forum Gen III V8 Specific
    Last Post: January 23rd, 2011, 02:39 AM
  2. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 11:01 PM
  3. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  4. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
