Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Were do I find Ben factor LTFT ?? or any ben factor I don't see any ben in my pids
  1. #21
    Quote Originally Posted by 04colyZQ8 View Post
    my custom map for maf, hi, lo created from hp tuners editor copied col axis, and by hand removed the extra comma on each one..fingers tired now lol:( will these work?
    Attachment 20933
    Attachment 20934
    Can you post screenshots of these maps.
  2. #22
    Feb 2009
    Yes hopefully later but the truck isn't driveable I put the ls2 silverblade tb on it and is it won't idle you touch the gas and the rpm stays up around 1500-2000,and won't come down causing it to over heat on idle, and high iat temps
    I can't for the life of me get the idle to stay at 600rpm? Any clue I tried adding 8% to the ve to richen it up and tried removing 2 from idle minum air flow 1200 rpm and under, still so lean when idle hangs it's 18% to lean
  3. #23
    Feb 2009
    Fixed the idle took 3.5 out of the entire base running airflow table
  4. #24
    Feb 2009
    Here is my log, and pids that match the log
    Log_1G6DN57U070115980_0021.efi
    pid to matclog.pi.pid
  5. #25
    I'll look at it later...
    can you also include your calc_pids.txt in case you've edited it from what I have.
  6. #26
    This is E38/E67 related so it would be better if I moved it to Gen IV section...
  7. #27
    Let's get rid of this pid, it's not working properly:
    - E38.AFRATIO_DMA
    You want to include these:
    - GM.ETCTP
    - GM.SPARKADV
    - GM.KR
  8. #28
    Looks like a fairly stable idle log.
  9. #29
    Feb 2009
    It's the last calc pid I posted should still be the same just lost power so I can't post it! Ok I'll make those changes it's not idling that bad after I subtracted 3.5 from the base running air flow, still try's to run away now and again, pcm sets timming to 2-5 degrees trying to stop it from idling high.
    That log tut trims were 5-10% off so that map ve table still isn't right? 1.0365 it read the hole time? It should be fluctuating more? And what is that value selben in the ve percent? Do I times my ve table by that? 1.0365 won't change much? It shout be more like 10.0365 maybe?
    Still so confused
  10. #30
    Are you running from MAF or VE...?
    Don't use VE%, use VE v*K/kPa...
    Yes, paste-multiply-with labels SELBEN into the VE, but only if it looks sensible...
    I meant to call you ladt week but I had too many "emergencies" at work...
    I'll call you on Monday.
    Sent from my LGMS345 using Tapatalk
  1. Whats a good range of BEN factor for MAF
    By pavetim in forum Gen III V8 Specific
    Last Post: January 23rd, 2011, 02:39 AM
  2. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 11:01 PM
  3. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  4. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
