Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: April 2017, Beta Release 1
    Dec 2005
    Sent !
    www.mscservices.net
    Sent !
    All three files load up fine in my version of V8 here.
    What exact steps did you go through prior to getting that error?
    In case it's a configuration issue, can you send me these files from your PC:
    \My Documents\EFILive\V8\Config\EFILiveScanAndTune.ini
    \My Documents\EFILive\V8\Config\EFILiveScanAndTuneLayo ut.ini
    \My Documents\EFILive\V8\Config\UserCalculatedPids.ini
    \My Documents\EFILive\V8\Dashboard\EFI_LB7_Sample_Metr ic.dsh
    Oct 2011
    CMD flash times seem to have slowed way down with this update. Standard/Fast CAN/ Fast CAN unlimited all take right around 17-19 min. Previous release (build 315) is ~7-8 min with Fast CAN.
    03 6spd
    Quote Originally Posted by BlackCPG View Post
    Unfortunately, yes you are correct. Those settings are being ignored. Will get it fixed asap in the next update.
    Feb 2012
    Any Update on the Update? Lol
    Sam
    The beta-2 update is due out this week. It's in testing at the moment. If testing goes well then it should be available in a day or two, if not then hopefully by the end of the week.
    Feb 2012
    Sounds good,
    Sam
    Update is now available here:
    https://forum.efilive.com/showthread...Beta-Release-2
  1. April 2016: EFILive Beta 2 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: April 30th, 2016, 08:49 AM
  2. Known issues with the April 2016 Beta Test Release
    Last Post: April 18th, 2016, 05:07 PM
  3. Known issues with the April 2016 Beta Test Release
    Last Post: April 10th, 2016, 08:23 AM
  4. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
  5. April 2016: EFILive Beta Test Release
