Results 11 to 18 of 18
Thread: April 2017, Beta Release 1
Threaded View
    Default April 2017, Beta Release 1
    Download EFILive V7.5
    Download EFILive V8
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Key Features:
    • Calibration updates for E38, E78, E80, E84, E98 and T76 controllers.
    • Expanded filename template capabilities.
    • V7 folder settings are no longer reset to defaults during software installation.
    • Added option to search for tune files based on segment checksums.
    • Removed serial wideband 25AFR display limit.
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.10 Build 324 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.5 Build 317 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.114 (Apr 02, 2017)To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Issue 3:
    When using "Save As..." in the V7 scan tool or tune tool software the save file dialog box does not automatically open in the folder from which the file was originally loaded.
    Workaround:
    Manually navigate to the required folder. Will be fixed in the next update.
    Issue 4:
    Applying a bitmask to an 8, 16 or 32 bit signed value in a *.cax file calibration definition displays the unsigned value not the signed value.
    Workaround:
    None. Will be fixed in the next update.
    Issue 5:
    The FPRACOM and FPRADES PIDs are not being handled correctly by the V7 scan tool software. If you include those PIDs in a V7 data log it may appear that multiple PIDs in the log file are corrupt.
    Workaround:
    Don't select those PIDs when logging LBZ/LMM using V7 or BBL.
    If you already have a log file with those PIDs in it that appears to be corrupt, try opening the log file in V8 to automatically strip out those two PIDs.
    Issue 6:
    The Cummins CMD/CME Fast CAN Mode options do not work. Flashing speeds are set to the slowest speed regardless of which setting you choose.
    Workaround:
    Issue 7:
    The V8 scan tool pass through data logging for VPW based controllers (LS1, LB7, LLY etc) only records data from some PIDs - not all selected PIDs.
    Workaround:
    Use the V7 pass through scan tool. Will be fixed in the next update.
  1. April 2016: EFILive Beta 2 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: April 30th, 2016, 08:49 AM
  2. Known issues with the April 2016 Beta Test Release
    Last Post: April 18th, 2016, 05:07 PM
  3. Known issues with the April 2016 Beta Test Release
    Last Post: April 10th, 2016, 08:23 AM
  4. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
  5. April 2016: EFILive Beta Test Release
