Results 1 to 10 of 11
Thread: 08 E38 electric fan problem
    Mar 2017
    Default 08 E38 electric fan problem
    hi I am defiantly a newbie to tuning iv been reading a lot and trying things. but for the life of me I cant get the fans to come on iv tried the fan patch I have messed with G0922 -G0927 iv tried G0901 I have tried all the PWN witch make the fan work but the relay start ticking really fast or slow depending witch PWM I chose I have no idea what to try next. this is a swap that came out of a 2008 chevy express van with a stand alone harness from painless wiring harness
    Are you trying to run a set of efans or PWM fan on a calibration that did not originally come equipped with them? Unfortunately, to do that, you need to change come parameters that are not available in EFILive, you will need to have someone modify the settings for you, use a different software to modify it or build a .cax file to add the parameters into your calibration.
    Mar 2017
    Yes I am trying to run just regular fans not pwm style.. so basically I should of got a computer out of something that was equipped with electric fans originally?
    Quote Originally Posted by Davidss View Post
    Got it, so a normal set of discrete-style efans. No, your ECM can handle it just fine, just EFILive doesnt have the tables needed to tweak the last few parameters to make it work properly. There are some people on the forum who may do it for free or a nominal fee. You could go through the hassle of getting an ECM out of a vehicle already equipped, but then you'll need to license another ECM and possibly re-work your harness.
    Also, I get a B1846 out of range error with your file, I'd suggest modifying these values slightly to ensure they're below the threshold. I have updated it in the attached file.
    I have attached a new tune that has a System segment copied from an 08 Escalade with the 6.2 as it is setup for efans from the factory. I have no idea if this will work or not, but you will need to full flash the tune into your ECM. If it works, you can then change the ECT and ACP fan settings and cal-flash from here on. Disclaimer: I am not responsible if this does not work or if it bricks your ECM. Proceed with caution and at your own risk. You will likely need to disable VATS again and if desired, apply the fan range patch again.
    Mar 2017
    thank you I will try it later tonight.
    Mar 2007
    I will try not to hijack this thread, but does anyone have a list of the GenIV ECM's that had discrete fans from the factory? It would help when trying to find a system segment to use for this type of application.
    Aug 2006
    Im having the same problem but i also have hpt so basically i can set it up with hpt b4 i go buying credits?
    Quote Originally Posted by JCA View Post
    HPT has the parameters needed to enable efans, there are a few threads on their forum on how to do this.
    Aug 2006
    Thanks erik bit frustrating i have to use other software for something basic like this
    Oct 2017
    did this fix for the fans work? I have the same issue with the fans
  1. E67 Electric Fan Help please
    By 2Aspire in forum E37, E38 & E67 PFI ECM's
    Last Post: April 25th, 2016, 04:44 AM
  2. Electric Fan Control
    By epb091786 in forum Duramax LB7
    Last Post: June 8th, 2009, 03:35 PM
  3. Electric Fan Problems using pin 33
    By chevy052500hd in forum Gen III V8 Specific
    Last Post: June 6th, 2009, 09:06 AM
  4. Electric fan install
    Last Post: October 11th, 2007, 12:39 AM
  5. Electric Fan Settings
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 08:24 AM
