Results 1 to 3 of 3
Thread: 2007 duramax 2500 diesel cp3 pump or injectors?
    Jul 2018
    Default 2007 duramax 2500 diesel cp3 pump or injectors?
    Recently had diagnostic at dealership, gave me a paper that shows fuel pressure rates, can someone interpret it for me, issue the truck was taken in for was a P0087 code only under load, heat and hill, truck has 280,000 miles, works great when not under load! Dealership said I need new injector pump and injectors, is it true? Have changed fuel filter religiously and used seafoam once a month, don't drive too much anymore on long trips
    Jan 2010
    P0087 is fuel rail pressure to low.
    It wants 179.8 MPA but is only seeing 134 MPA
    There stating the PUMP is weak and not able to supply the commanded pressure. Typically higher mileage injectors tend to leak or fail so they are recommending you do them at the same time.
    Jul 2018
    Quote Originally Posted by 1FastBrick View Post
    Thank you
  1. 2007 Isuzu Topkick w/5.2 Duramax
    By Road in forum General (Diesel)
    Last Post: October 12th, 2015, 09:43 AM
  2. 2007.5 lmm duramax
    By driver456 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 2nd, 2015, 06:24 AM
  3. CP3 or Injectors????
    By TonOfDalt in forum Duramax LB7
    Last Post: August 5th, 2012, 01:14 PM
  4. bigger injectors and fuel pump
    By aaronr in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 5th, 2008, 05:09 PM
  5. Replies: 2
    Last Post: June 28th, 2007, 02:41 PM
