Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 104
Thread: 2017 Duramax
  1. #41
    Dec 2005
    Guys, there is no encryption on these ECM's, lets get the terminology correct.
    There is a password on the 'back door' as it was put (and sorry, it is 64 bit, not 128), but either way you ain't getting in unless you know it. This is the password that protects the ECM from being opened up and the flash dumped out using JTAG tools (Google PowerPC censorship password).
    The flash segments again are not encrypted in any way, they just have a SHA-256 signature included that nobody other than GM can calculate with their private key that must be sent and validated during the OBD-II flash.
    So yes doors are closed and the keys broken off in the lock, nothing to see here folks please move on to your nearest Dodge or FORD dealership.
    2017 FORD is in need of a locksmith as well it seems.
    www.mscservices.net
  2. #42
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Quote Originally Posted by GMC-2002-Dmax View Post
    Its one ECM, I am not sure there is any difference other than the harness and the code, I am waiting to get one, even if its just for testing on my 2012 LML.
    I highly HIGHLY doubt it will work in a factory truck. Im sure its strictly for standalone applications.
    Which would still be nice...because as of right now, its impossible to make an LML run in standalone without keeping the BCM, TDM, and original ignition key. So this aftermarket ECU would give engine swap guys a nice alternative to a complex standalone harness that has additional wiring for the BCM etc.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  3. #43
    Oh dear.
    I don't think it is in any of this generation EDC17 ECM's but I had read last year about the new Bosch ECM's that were coming out that did have on the fly decryption meaning everything stored in the ECM is gobbledygook unless you know the private decryption Key (there's that private key thing again). That is even one step beyond what we are dealing with today.
    Out of interest, read page 6 of the pdf in the link below, this explains exactly what GM have implemented in the E41.
    http://www.nxp.com/assets/documents/...SECURITYWP.pdf
    Quote Originally Posted by DURAtotheMAX View Post
    I would say it'll be like many of GM's late model gas ECM's where there is no specific theft disable calibration, we have to patch the OS in those to make them run standalone. Unfortunately (here we go again) the LML OS sections are protected with a digital signature.
  4. #44
    Dec 2005
    Reading that made my head hurt !!
    www.mscservices.net
  5. #45
    Nov 2005
    I wonder if there are any vulnerabilities via the secondary CAN controller.
    12.9s @ 108 mph
  6. #46
    I can't see how that would be possible, once the ECM is put in to programming mode it would not be listening to any other modules on the bus.
  7. #47
    Jan 2017
    Oh dear.
    That's probably less about keeping the aftermarket out (I mean, the signatures is enough, right?) and more about keeping researchers from discovering diesel defeat devices. ;-)
  8. #48
    Lifetime Member LB72004's Avatar
    Dec 2011
    Very unlikely. The researchers didn't need to examine the VW code to see something was wrong. Also a court order can force GM to reveal the emmision strategy/code if the epa/carb had enough to show something was not right.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  9. #49
    Jan 2017
    Quote Originally Posted by LB72004 View Post
    One can't deny that researchers could have (maybe not quite so easily) reversed engineered the ECU code to find the defeat device code, right? If the code is encrypted, however, reverse engineering is a much less feasible (likely impossible, as Ross said) option.
  10. #50
    Quote Originally Posted by sn00py View Post
    The code is not encrypted so they aren't trying to hide anything, it's just digitally signed to stop people modifying it.
  1. 2017 8sp support
    By sn00py in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 18th, 2017, 02:11 PM
  2. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  3. 2017 T87 Silverado Calibration Support?
    By Doc in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 23rd, 2017, 04:48 PM
  4. 2017 duramax
    By djv86 in forum General (Diesel)
    Last Post: June 24th, 2016, 11:48 PM
