Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 104
Thread: 2017 Duramax
  1. #51
    Nov 2010
    The code is not encrypted so they aren't trying to hide anything, it's just digitally signed to stop people modifying it.
    Ross,
    Can you explain this digital signature for those who don't understand it vs encryption?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  2. #52
    Quote Originally Posted by 2007 5.9 View Post
    Ross,
    I had a link a few pages back to a Wiki article that demonstrated the signature system GM used.
    https://forum.efilive.com/showthread...l=1#post238349
    But as simple as I can put it.
    A digital signature is used to validate data.
    Encryption scrambles the data so it is not 'readable' until Decrypted.
    Unfortunately the digital signatures these days are so complex they cannot be tricked and can valid ones can only be generated by GM.
  3. #53
    Jan 2017
    Yes, I was referring to Bosch's apparent future plans to encrypt/decrypt on the fly.
  4. #54
    Right ok, yeah that sounds bad. These are the CPU's they are going to be using. Goodnight to tuning for anything running that.
  5. #55
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Dumb question...Dont the newer tunable cummins ecms have a similar signing and a way to patch it so it'll accept unsigned calibrations?
    Sent from my 2PS64 using Tapatalk
  6. #56
    Yes but they have an exploit to turn it off. The signing is solid, they just left a gap in the door. At this stage it doesn't look like GM made the same mistake.
  7. #57
    Jan 2006
    There is no encryption as such but there is SHA-256 signatures on every calibration segment and the OS, no external reflash bootloader permitted so the signature validation cannot be bypassed and to top it off the JTAG/BDM is 128bit password protected.
    Be prepared to accept that these may never be tunable, nobody but GM can generate the SHA-256 signatures and if someone does they will likely be sued by GM because SHA-256 is not crackable.
    Hi, do someone know what tool was used to confirm the JTAG/BDM is 128bit password protected , any board pictures available
    tks
  8. #58
    We use P&E Micro's equipment for BDM purposes......and the BDM password is different on every ECM.
  9. #59
    Jan 2006
    Hi, do you recall the ecu family , were you able to access the pad board by removing the thin cover or it required to completely dismantle the box, tks
  10. #60
    CPU is a MPC5676R.
    There is no BDM pads in a row, the connection points are spread out all over the PCB... and no we aren't showing where they are, we had to destroy an ECM to trace them out .
    Forget BDM, honestly you are wasting your time.
  1. 2017 8sp support
    By sn00py in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 18th, 2017, 02:11 PM
  2. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  3. 2017 T87 Silverado Calibration Support?
    By Doc in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 23rd, 2017, 04:48 PM
  4. 2017 duramax
    By djv86 in forum General (Diesel)
    Last Post: June 24th, 2016, 11:48 PM
