Results 1 to 6 of 6
Thread: Unknown Autocal
    Jan 2015
    Default Unknown Autocal
    I bought a truck that came with an Autocal and locked tune. First is there a way to ID the programmer through the serial number. Second if I can't find the programmer can I waste another license and program it with my V2.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    If you look at the file names, you MAY be able to determine who's V2, the Autocal is linked to. If you post the files names here someone may be able to help find the tuner by the naming format of the files. The EFILive folks on here may be able to help you out by serial number as well.
    No, buying a new VIN license won't do anything for you. Once an Autocal is linked to a V2, it can only be unlinked by the person who has that V2.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Jan 2015
    I'm not looking to use the Autocal I just didn't know if I could completely reprogram the ecu with my v2. I will get some pictures up when I get home
    Jan 2015
    Ok thanks for the help KhakiCummins.
    EFI Live license # 003632648534
    File name on Autocal FPE_DSP5
    Autocal serial# 5000472477
    Sep 2011
    based on the file name, I'm guessing it's Fleece Performance.
    http://fleeceperformance.com/
    If you contact them, they should be able to tell you if it's linked to their V2.
    Duane
    Jan 2015
    I forgot to add that this is a 2006 LBZ
  1. E86b Unknown PID's
    By vortecfcar in forum Black Box Logging
    Last Post: May 8th, 2015, 09:56 AM
  2. Unknown E67
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: January 16th, 2011, 11:24 AM
  3. Unknown Bucking???
    Last Post: January 14th, 2008, 12:41 AM
  4. Cable unknown???
    Last Post: October 8th, 2007, 12:51 PM
  5. Unknown VIN ???
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 12:54 AM
