Injectors are stock LS3, L99, LS7 42lb 58psi, word is that they and pump should be OK.
Camaro SS Hyper Blue EU -19
It started to make MILs, lean, maf,... First I thougt to put stock air filter back, JLT tube has bigger dia so air is moving slower in it and causing problem,but instead put 20% factor to maf valjues, also idle to 600 instead of 525, slow idle I did not like with gas either, and MILs went away, also starts are good and idle smooth 610-620 no hunting so far...
