Results 1 to 4 of 4
Thread: Full flash
    Jan 2006
    Default Full flash
    Whats involved in doing a full flash from a differnt year pcm. For example, if I had a pcm from a 99 and wanted to flash it for a 2000, or if I had a 2004 pcm and wanted to flash it for a 2003? Will it matter what stock OS was in the car to start with? I have a 04 pcm and a stock 03 tune but differnt OS than it came with, if I do a full flash of the 03 tune I have with the differnt OS than the car came with will it work?
    Oct 2004
    From what i understand you just go right ahead and flash it. The PCM is like a computer and you can load any operating system on it (Windows Linux - to use the PC analogy).
    You will just have to be sure that it is a 512k or 1MB PCM that you need.
    Andrew
    EFILive Crew
    Member bK's Avatar
    Mar 2004
    Quote Originally Posted by Tordne
    How do you tell the difference? Which O.S.'s needs 512k or 1MB? I know I've got a 512k PCM.
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
    Oct 2004
    In the first screen of a tune there is the Calibration Summary. There is a field called "PCM flash" which has the size of the PCM required for the image.
    Andrew
    EFILive Crew
  1. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 11:43 AM
  2. Full Flash
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: November 26th, 2009, 09:25 PM
  3. trying to full flash tcm
    By j-man345 in forum Allison 5 & 6 Speed
    Last Post: August 12th, 2009, 02:03 PM
  4. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 06:05 PM
