Results 11 to 20 of 23
Thread: Flex fuel OS for LS1 PCM
    May 2015
    Ok so those are a 512k is the other VZ one a 411?
    So ls1a ecu's were pre 1999.
    ls1b ecompases both P01/P59 ecu's.
    Pre99 & P01 is 512kb
    P59 is 1024kb
    P01 is blue/red connector
    P59 is Blue/Green connector
    Apart from some minor pin changes and slightly different shape on the green connector, it's almost plug/plug between the 2. You can file down green the connector plug and away you go
    May 2015
    Ok awesome so are the P59 a simple plug and play? Or do some pins need to be moved around
    Mar 2009
    There was a huge stink over on the Corvette forums about this and supposedly 1 dude had it figured out but wasn't talking. I need to update my software to view a ctz, but are there any weird tricks or asspain other than a full flash of that tune onto my P59 in my 2004 Z06? I picked up a blower for it and really want flex fuel ability.
    There is a current thread on LS1tech.com regarding this, let me see if I can find it...
    Mar 2009
    I think I saw it too. I'd found more info on the swap but apparently not on the Corvette Forum because when I checked back there I couldn't find what I'd remembered reading.
    Aug 2006
    So basically we need to run a vz ls1 ecu but then we have the problem of dbw
    May 2015
    Quote Originally Posted by JCA View Post
    I reckon the Yukon is still cable that uses this PCM so should be able to use that OS
  9. #19
    no. u still keep cable throttle body.
  10. #20
    Mar 2009
  1. Flex Fuel Sensor and 0411 PCM
    By turbo_bu in forum Gen III V8 Specific
    Last Post: February 2nd, 2016, 06:10 AM
  2. Flex Fuel for LS1
    By mr.prick in forum Custom Operating Systems
    Last Post: July 6th, 2014, 05:21 AM
  3. new flex fuel sensor with 411 pcm
    By LS1Inferno in forum Gen III V8 Specific
    Last Post: June 22nd, 2013, 12:14 PM
  4. Replies: 3
    Last Post: September 20th, 2011, 01:04 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
