Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Flex fuel OS for LS1 PCM
    May 2015
    Default Flex fuel OS for LS1 PCM
    Does anyone have a stock tune file for a 12216125 OS or any other OS that I can use for flex fuel in a LS1b PCM.
    See if you can find it in here: Tunefiledepot-has-been-replaced
    May 2015
    Cheers Joe, didn't realise tune file depot had been replaced that's awesome news, will have a look
    May 2015
    Yep found it in there thanks again joe. Does anyone know if there is a flex fuel enabled GM OS that is also custom OS enabled for boosted applications.
    Yes, but I dont believe for 512kb LS1 PCMs with EFILive. You'd have to go to 03-05 1MB LS1B PCM to get that.
    May 2015
    Do you have a OS Number? Or what year and vehicle it came out of. The PCM I have is a LS1B as far as I know. From a 2003 VY commodore
    get a vz ls1 1mb ecu, then you can run e85 compatible os.
    I'm pretty sure i have posted a base tune on the forum here already with e85/custom os
    May 2015
    ok so the VY PCM isn't a LS1B? That sucks, might have to source one for mine as it will be boosted the other car I'm doing is a Holden 355 running the LS pcm using a low frequency trigger.
    it still a ls1b ecu, but it's called a p59.
  1. Flex Fuel Sensor and 0411 PCM
    By turbo_bu in forum Gen III V8 Specific
    Last Post: February 2nd, 2016, 06:10 AM
  2. Flex Fuel for LS1
    By mr.prick in forum Custom Operating Systems
    Last Post: July 6th, 2014, 05:21 AM
  3. new flex fuel sensor with 411 pcm
    By LS1Inferno in forum Gen III V8 Specific
    Last Post: June 22nd, 2013, 12:14 PM
  4. Replies: 3
    Last Post: September 20th, 2011, 01:04 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
