Thread: Tire Size Calculator out by 5%?
    Jan 2009
    Default Tire Size Calculator out by 5%?
    Has anyone else been having this problem lately? We been setting the tire size to the customer supplied size and on 3 or 4 different occasions now it has been out by 5%. I dont have the trucks on hand so I couldnt confirm the actual size of the tire (I asked them to check, waiting to hear back).
    One customer has his tire size set to 31.75" with a ppe yet we set it with the efilive calc and it was 31.7, so it all seems good, but yet they are saying it is now out by 5% and the tire size we supplied with that adjustment is 30.2". The rear differential is 3.73s and confirmed.
    I find it just so odd that the PPE would be happy at that OD and efilive needs a different one. Not sure how that would even be possible, that said I have not confirmed this in person, only going off what I am being told.
    Just curious if anyone else has seen this on their day to day work? Seems odd.
    Mar 2009
    I always do it by tire height, or I look up the tire, and get the rev's per mile from the manufacturer to plug in. The calculator has always been off for me.
    Dec 2005
    I always ask for an exact measurement
    www.mscservices.net
    Mar 2007
    It's been my experience that the factory calibration is always off a little bit. I figure it was GM's way of a fudge factor to make it work out. When doing tire size changes, I always start out with the GM calibration value (already fudge factored) and do the relative size correction. So far, this has worked everytime.
    Jan 2009
    Lifetime Member LB72004's Avatar
    Dec 2011
    I had to use what the manufacturer says for revs per mile. it is about 1/2 MPH off according to GPS
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  1. Tire size help
    By 08pearlZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 23rd, 2014, 02:37 AM
  2. going to stock tire size
    By Bad_Red_Sheep in forum Diesel
    Last Post: February 7th, 2013, 01:17 AM
  3. Shift point calculator, and tire size
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: October 12th, 2010, 01:10 AM
