guess time for me to sit done and figure it all out. cause how suncoast and two other companies sell it all day long and ask for a 5 spd tcm as a core in return. time to sit down and figure it all out. just saying.
They use a 5 speed TCM, but it is NOT a factory 6 speed TCM tune. The 6 speed TCM is a GEN IV a40 or newer style TCM. The 5 to 6 speed conversion kits use a 5 speed TCM tune that has been hacked to add in 6th gear. It has NOTHING in common with a factory 6 speed tune or TCM other than it has 6 gears. There is another tuner out there who used to sell the 6 speed tune, and you could use a 6 speed valve body and modify the tune file to operate the newer lockup solenoid(drop max duty cycle back from 99% or whatever it is back to 67% which is max for the stock 6 speed solenoid) and make it work as quite a few people did it. It was a hacked copy of the 04.5-05 conversion kit, so you had to do something about the missing G solenoid if you used it in a LB7, and there was no way to lockout 5th if you put it in an 01-02.
Custom Tuning Services
