Results 1 to 7 of 7
Thread: 2015 z06, procharger, anybody got one to run with no MAF?
    Feb 2006
    Default 2015 z06, procharger, anybody got one to run with no MAF?
    Have a 15 camed, F1A. Runs excellent in sd but engine torque cammanded and output is real low causing throttle to only open 40%. I e changed all torque tables and eq tables. Nothing touches it. I've heard hpt has a table that can be switched to map only. Any ideas?
    Is this an E92...?
    Post the stock tune file.
    ~ by phone ~
    Feb 2006
    E92- Seen on another thread people talking about it but nobody posted they got it to work. I know it has to do with code 102 and the lack of reading the MAF/baro. Checking with HPT because I heard they have a drop down to put the computer to read just the MAP. Hopefully that works.
    As for the tune, I messed with all torque modeling table's with no help or change at all. Commanded torque stays low.
    Dec 2014
    All the E92 DI conversions I have in the world run speed density no MAF. They work great.
    To answer your question though, yes HP has a sensor config drop down to take care of the problems.
    Edit, TC does as well. I'll have to confirm that when I get home later. Thing that sucks is I have had to bounce between the 3 different tuning offerings to make a few of these work correctly.
    So you can't get E92 to run SD by simply failing the MAF...?
    This makes me think that the MAF DTC's cause the MAP to not be read, is this what is happening...?
    ~ by phone ~
    Dec 2014
    ~ by phone ~
    On the NA apps you can, depending on year and make. On the FI apps you have to either start with an NA tune or swap the settings shown. Usually I just start with an NA tune and go from there.
    One thing really needed is a minimum idle adjustment like the E38s have defined, if there is such a thing. I still run into idle dip that goes straight to the stock setting.........
    Feb 2006
    Got it running excellent in sd. Just the throttle is limited to 400ft/lbs of torque max. Or around there. Tried everything in efi and nothing touches it. This is a z06 computer/car. Not a reg na c7, those work fine.
    The car, even though camed, f1 ect runs/drives excellent just need full throttle to finish it. I have to break out my hpt and try running on just the map.
  1. Replies: 12
    Last Post: August 31st, 2015, 10:04 AM
  2. 2015 Z06 Auto
    By Jason S. in forum General
    Last Post: July 7th, 2015, 03:38 PM
  3. 2015 Z06 Avail for tuning?
    By TFZ_Z06 in forum General
    Last Post: April 7th, 2015, 09:18 PM
  4. Replies: 1
    Last Post: July 10th, 2010, 09:15 AM
  5. Will 12212156/COS5 run on PCM used in 2003 Z06...?
    By joecar in forum Custom Operating Systems
    Last Post: August 8th, 2007, 03:01 PM
