Results 1 to 10 of 14
Thread: 2005 LLY No SRT's are enabled? Wont Pass SMOG California
    Mar 2014
    Default 2005 LLY No SRT's are enabled? Wont Pass SMOG California
    Hoping to get some help regarding an issue im having with an LLY. I typically get quite a few trucks in my shop (in southern california) that wont pass smog because they have had an after market tuner used on them and even though they were set back to "stock" the readiness monitors still wouldn't enable. Heres the weird issue im having with a 2005 LLY. ive flashed the vehicle with GM's SPS software back to stock and still when I look at it the readiness monitors are almost all set to "not supported" does anyone have an idea? attached is the pictures of what it looks like and the OS
Name:	LLY not supported.PNG
ID:	20977   Click image for larger version.
    Dec 2005
    maybe it has to actually run for a while, I know there are some issues with gasser when resetting an ecm the VW as an example need a period of time to either run a test or complete a test to obtain that readiness status, its a method to prevent a cheated test by resetting an ecm that may not recode again until some other event happens.
    Not sure how the ecm is actually reporting the bits on or off to the scan tool.
    www.mscservices.net
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by blades11b View Post
    Most if not all of those test are not supported because they are test in reference to a gas motor. I don't know much about California emissions but I would thing the not supported would be ignored when testing.
    Please be more detailed about the failure specifics. I guess you are saying they are failing at the obd plug in??? And NOT opacity?
    Custom Tuning Services
    Senior Member djv86's Avatar
    Nov 2014
    You flashing them back to stock with a v2? Or dealer equipment ?
    Nov 2014
    And a new thing recently came out if the smog machine realizes invalid data from vehicle it must be sent to referee.
    Lifetime Member LB72004's Avatar
    Dec 2011
    That certainly is odd. You should have misfire, comprehensive component and egr supported.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Nov 2014
    By building the vehicle on tis2web. It's a federal vehicle. Are they running it on the smog machine as a cali vehicle ?
    Dec 2011
    I didn't think there was a federal version of the LLY. Regardless it should have at least the misfire and comprehensive components even if it doesn't have an egr
    Nov 2014
    Reguardless what monitors are or are not on the vehicle. I'm just asking if the smog tech selected it as a federal vehicle or California vehicle. I'm a smog tech myself and the other smog guy at my shop smogged a diesel which was a federal truck as a California truck and the smog machine wouldn't communicate
  1. Ab 2289 new california smog law---any affect on the tuning world ????
    By tblu92 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2016, 07:30 AM
  2. Setting up to pass smog...check this out
    By TFZ_Z06 in forum Diesel
    Last Post: May 8th, 2015, 06:20 AM
  3. Manual trans os for a 2005 LLY
    By ShawnM in forum Duramax LLY
    Last Post: May 6th, 2012, 02:05 AM
  4. Need Tune to Pass Smog Testing in Colorado
    Last Post: March 13th, 2012, 03:19 PM
  5. 2005 LLY Fuel mileage
    By dieknow in forum Duramax LLY
    Last Post: February 7th, 2006, 05:54 PM
