Results 1 to 2 of 2
Thread: 2015 cme $0340 error
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Default 2015 cme $0340 error
    I have a dealer with a problem truck that will not accept a csp4 flash. It kicks him off with $0340 every time. Sometimes it almost completes and others it only gets half way then it boots him. He was finally was able to get a stock file back in after 2 attempts. First time it kicked him off with $40. This dealer uses an autocal to flash trucks and I have had him try both autocal and pass through. Have tried "assume lock may be faulty" and with "Fast CAN" off. Nothing seems to work. It is like the ECM is still locked. He unlocked it using an Edge Insight. I have remote into his computer to make sure everything is up to date and it is. We both are running V8.2.5.316. Does anybody have any ideas? I am kind of at a stand still with it and exhausted all my resources I know to do. Much appreciated.
    Jun 2011
    Problem solved. After we got the stock file in we tried the unlock again. Edge did it's thing and then $0340 again.. Finally after a a third time it actually unlocked and would accept a modified flash. Edge said it successfully unlocked all 3 times so looks like they didn't finish their R&D
  1. 2008 with error code 0340.
    By Curt in forum Cummins 6.7L
    Last Post: December 18th, 2016, 10:15 AM
  2. CME ecm error 400000 when using tune tool
    By modpcm in forum Cummins 6.7L
    Last Post: October 12th, 2015, 05:20 PM
  3. $0340 error
    By billybob in forum Cummins 6.7L
    Last Post: February 16th, 2015, 03:42 AM
  4. help error 0340
    By easymon in forum Cummins 5.9L
    Last Post: September 25th, 2011, 10:24 AM
  5. Error $0340
    By comnrailpwr in forum Cummins 5.9L
    Last Post: August 15th, 2011, 06:53 AM
