I scaled my VE tables and Injectors 20% to keep my car from going into Reduced Power at upper RPMs/ Boost. My understanding from what I've read is that torque calculations are derived using airflow and a few other variables. Scaling would affect those calculations so my Delivered Engine Torque used in Transmission Pressure would be incorrect. The calculation would be lower than actual torque.
How can you adjust for this?
2004 Corvette Level X RPM 4L65E, 427, 23lbs boost, 2.5 bar OS
