Getting the dpf full message when traveling 70. Power then drops to 45. Have to pull over and shut down. Once back on the road runs fine for 30 miles then happens again. Any help? Have the 2010 dodge 6.7.
This would be better suited question for the dodge cummins forums. This is not likely an EFI live related issue. If you have tuning with EFI platform, talk to your tuner. However the message means DPF is clogged and if it is not cleaning itself you may be looking at needing to remove and have it cleaned at a facility or replaced with a new unit.
