Download EFILive V7.5 (Updated to build 326 on April 21 to fix issue #4)
Download EFILive V8
We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
Release Notes:
Key Features:
- Added extended descriptions for encoded PID values for most PIDs.
- Fixed Cummins "Fast CAN" mode for CMD/CME controllers.
- Fixed "Save As..." option so that it correctly defaults to the file's original folder.
- Fixed V8 pass-thru scanning not working on VPW based controllers.
- Fixed signed bitmask definitions in *.cax files (fixed in build 326).
Version Numbers:After installing this beta release you should have the following software, boot block, firmware versions installed:
- EFILive V7 software: V7.5.10 Build 326 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.2.5 Build 318 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
- Firmware: V2.07.115 (Apr 18, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
Known Issues:
Issue #1:If you are Black Box Logging PIDs from an ECM and TCM simultaneously and you have selected a PID from the transmission controller (TCM) that has an identically named PID in the engine controller (ECM), then when the log file is loaded back into the V8 software for viewing, that TCM PID will be displayed as if it originated from the ECM. The PID's data will have correctly been logged from the TCM, only its name will appear to indicate that it was logged from the ECM.
Workaround:None.
Issue #2:When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Issue #3:The FPRACOM and FPRADES PIDs are not being handled correctly by the V7 scan tool software. If you include those PIDs in a V7 data log it may appear that multiple PIDs in the log file are corrupt.
Workaround:Don't select those PIDs when logging LBZ/LMM using V7 or BBL.
If you already have a log file with those PIDs in it that appears to be corrupt, try opening the log file in V8 to automatically strip out those two PIDs.
Issue #4:Defining a bitmask on a signed negative value in a *.cax file definition causes the tune file to fail to load.
Workaround:Update to V7.5.10 Build 326.
