Results 1 to 4 of 4
Thread: cos3-b3618/b3647
    Nov 2014
    Default cos3-b3618/b3647
    how do these work together? is 3647 when not in pe and 3618 takes over when in pe? or is there more to it?
    In OL, the richest of the the active tables commands fueling.
    When PE is not active, only OL fueling table is active so B3647 commands fueling.
    When PE is active, the active tables are B3647 and B3618, so at the operating cell (which is dynamically moving), the richest of those tables commands fueling.
    Nov 2014
    makes sence. thank you.
    Also note, in some systems, if commanded fueling (determined by the richest of the active tables) is leaner than stoich, then stoich will be commanded...
    but that ^ is not important because at WOT you should be commanding much richer than stoich.
  1. B3618 using LTFTBEN for update to fueling
    By stigmundfreud in forum Gen IV V8 Specific
    Last Post: July 6th, 2010, 01:21 PM
  2. COS3 initial NA setup, B3647, A0014 and A0008 ????s
    By BlackGMC in forum Custom Operating Systems
    Last Post: January 14th, 2008, 12:18 PM
  3. Discussion about PE Modifier Based on RPM (B3618)
    Last Post: November 17th, 2007, 08:56 AM
  4. B3618 PE based on RPM
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 22nd, 2006, 08:38 AM
