Results 1 to 9 of 9
Thread: E38 (08 C6 ZO6) - Speed Density "Service Traction System" P0102
    Sep 2016
    Default E38 (08 C6 ZO6) - Speed Density "Service Traction System" P0102
    I have an issue with my 08 C6Z displaying the "Service Traction System" message on the DIC and disabling traction control. My Autocal displays a P0102 code due to the missing MAF and when I clear the code, the traction light will go off but returns 5 seconds later with the same P0102 code.
    I understand that the P0102 code will be thrown with the speed density tune but I'm wondering if there is any way to get my traction control system to not disable because of this?
    The patch has been installed and I don't have a CEL, just the Traction Control light.
    Any help would be greatly appreciated!
    Thanks,
    Adrian
    Sep 2016
    BUMP
    Anyone have any ideas?
    Dec 2014
    There is a traction control patch that needs applied for SD.
    Sep 2016
    Quote Originally Posted by Team208Motorsports View Post
    Thanks for the reply!
    I will ask my tuner to look for it and send me a new file.
    Sep 2016
    Would you happen to know which patch is the correct one?
    I keep finding B9901, B9902, and B9903 through research but no definite answer for which is the TCS patch.
    Thanks,
    Adrian
    Connect your FSV2 to your laptop, open the V7 (V7.5) tunetool, in the Engine folder you will see a red subfolder "Operating Syste,m Patches", go into this folder, you will see B9901, B9902, B9903, they each have descriptions.
    Sep 2016
    Joecar,
    I'm pretty sure we have it correct in the tune but would you be able to open the attached file and confirm?
    Thanks for your help!
    Adrianft5 full flash.ctz
    Quote Originally Posted by Adjellin View Post
    Joecar,
    This is what I get when I open it in V7 tunetool:
    [Window Title]
    Error
    [Content]
    EFILive cannot load the file: C:\Users\jcarnuccio\Downloads\ft5 full flash.ctz
    This file is flagged as private. The contents cannot be viewed using the EFILive V7 software, please use the EFILive V8 software instead.
    [OK]
    This is what I get when I open it in V8:
    [Window Title]
    Warning
    [Content]
    Security options are active for this file, it cannot be edited using the V7 software.
    Please remove the security options using [F4: Properties]->Security Restrictions and then retry.
    [OK]
    Sep 2016
    Thank you for trying! I will consult with my tuner.
    Thanks,
    Adrian
  1. Replies: 13
    Last Post: July 3rd, 2014, 01:52 PM
  2. Replies: 13
    Last Post: July 1st, 2014, 02:38 PM
  3. P1571 "traction control torque request circuit"
    By HOWQUICK in forum Gen III V8 Specific
    Last Post: February 6th, 2013, 08:41 PM
  4. LMM "Trailer Brake System Service" message after DSP OS flash.
    By LReiff in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 20th, 2012, 07:12 AM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
Tags for this Thread
