Results 1 to 3 of 3
Thread: B3704 Injector assignments, just for clarification please.
    Jul 2012
    Default B3704 Injector assignments, just for clarification please.
    I feel like I know this answer, but I want to be sure. All the threads I have come across to this point just say "adjust b3704" but they don't go further than that. The swap in question is a 1995 LT1 running a custom harness, 0411 PCM, coil on plug, and an EFIConnection crank and cam sensor kit. The harness has had the 4-3 and 7-2 wires set up correctly, the engine runs great in open loop. Going to closed loop the trims get a little out of whack, which brings us here.
    I fully comprehend that we now have to change the bank assignments so that the correct cylinders correspond to the correct bank. What I am not sure of is how the injectors are identified within this software. Here is a screen shot of a FACTORY LS1 injector assignment, so in other words it set up for the original LS1 engine, 18726543
    In my mind this should be the correlation:
    Cyl# 1 2 3 4 5 6 7 8
    Injc A B C D E F G H
    But when looking at the stock screenshot it appears the injector letter corresponds to the LS1 firing order...
    Cyl# 1 8 7 2 6 5 4 3
    So even though my brain wants my first example to be correct, EFIlive/GM has set it up to be the 2nd example, correct?
    I don't quite remember anymore, it's either as you said (follows engine firing order), or reversed engine firing order...
    Cylinders: 1-8-7-2-6-5-4-3
    Coils: A-B-C-D-E-F-G-H
    Injectors: H-G-F-E-D-C-B-A
    both ways match B3704.
    Jul 2012
    I can't imagine a reason for it to be reversed
    H G F E D C B A
    1 8 7 2 6 5 4 3
    But either way it appears that it corresponds to the LS firing order.
  1. Replies: 20
    Last Post: May 4th, 2018, 04:28 PM
  2. Mode Assignments Locked out?
    By RADustin in forum Duramax 2011+ LML / LGH
    Last Post: August 13th, 2014, 09:54 AM
  3. B3704 and injector timing questions
    By JUSTASBC in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2013, 06:33 PM
  4. B3704 Injection Bank Assignment
    By Lextech in forum General (Petrol, Gas, Ethanol)
    Last Post: July 16th, 2008, 02:48 PM
  5. Injector flow rate table - clarification sought
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2005, 11:08 AM
