Results 1 to 4 of 4
Thread: Tow haul mode
    Aug 2011
    Default Tow haul mode
    Can the scanner be used to tell if the transmission is in tow haul mode? trying to diag if its the switch on the shifter or a bulb issue in the dash.
    Kyle
    Oct 2015
    As long as that's a PID that can be viewed.
    Dec 2012
    Quote Originally Posted by cyipher View Post
    Kyle
    IIRC, Log 'Transmission State 07'
    There should be one called Trailering/Hauling Shift Pattern
    Another that might work is 'Transmission State 08'
    Secondary Shift Schedule (input)
    I dont remember exactly, but atleast one of those should trigger with the tow haul button.
    Josh
    '04 GMC LLY
    Mar 2009
    Theres actually 2 pids that change when in tow/haul mode. I don't remember which one it was, I just know I logged all of the transmissions state pid's, and there was 2 that changed when it actually went into tow/haul mode. I found this out after I ran a TCM from a tuner who said he put tow/haul on a toggle switch for me. It changed the secondary shift schedule pid, but not another one, and it never left normal shift mode other than it changed to a different a adapt set when the toggle switch was on. Wish I could remember more, but it's been almost 8 years now since I was trying to figure that out.
  1. tow/haul mode?
    By THEFERMANATOR in forum Conversions / Aftermarket Parts
    Last Post: February 3rd, 2010, 07:43 PM
  2. Tow/haul mode
    By rennoc442 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 21st, 2009, 08:31 AM
  3. Lock Up in Tow/Haul mode?
    By coryhussey in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 22nd, 2008, 09:45 AM
  4. Tow/Haul mode?
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: March 27th, 2007, 07:23 AM
  5. Tow/Haul Mode
    By 87gmc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 19th, 2005, 11:54 AM
