Results 1 to 10 of 16
Thread: HCI LS7 what to do first?
    Nov 2011
    Default HCI LS7 what to do first?
    Hey guys, I just got my car back together. 2006 Z06. The heads are ported Trickflow 260s, cam specs 240/254 on a 114 +3, and a ported MSD intake. Any tips for initial changes to make to get this thing going? I have done some LS1 tuning but haven't looked into the E38 stuff much at all. Any help is appreciated.
    Same ideas:
    - make sure injector tables are correct (including any scaling if you're running out of injector range or MAF range),
    - correct VE with MAF disabled (MAF DTC showing) and CL/trimming disabled,
    - correct MAF with VE disabled (dynamic air threshold) and CL/trimming disabled,
    - setting timing on dyno,
    - steet/drivability tuning,
    - idle tuning.
    See this thread (post #117): E38-VVE-Setup-Guide
    Also, there is stuff you can use from this LS1 thread: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    Nov 2011
    Cool. Thank you. Anything i should adjust before startup? Injectors haven't changed so that can stay. I just remember for the LS1 bumping up idle airflow just to get the car running.
    increase desired idle rpm.
    Nov 2011
    Well that wasn't as bad as i thought. Now if only i could get DFCO to work again. No DFCO MAP table in the E38. I see B2404 (DFCO Airflow Threshold) but.....milligrams?
    Quote Originally Posted by spy2520 View Post
    B2404: those might actually be in g/s.
    Post your tune file.
    I don't see anything under DFCO/CFCO that would prevent DFCO from enabling...
    do you have the stock tune file to compare against...?
    Nov 2011
    The DFCO settings are stock i believe. If it were an LS1 I'd assume due to the cam, the MAP may settings for DFCO may need to be adjusted. But thats not really an option here.
  1. LS7 inj??
    By Chuck L. in forum General (Petrol, Gas, Ethanol)
    Last Post: February 25th, 2013, 06:55 AM
  2. LS7 tune
    By Warren in forum E37, E38 & E67 PFI ECM's
    Last Post: January 25th, 2011, 01:56 AM
  3. Tuning LS7
    By johnsZ06 in forum Gen IV V8 Specific
    Last Post: May 15th, 2009, 02:19 AM
  4. Ls7 Ecm
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: December 9th, 2008, 07:44 AM
