Results 1 to 7 of 7
Thread: bench harness
    Jan 2006
    Default bench harness
    Has anyone made there own harness from just having the two plugs? I came across the plug for the pcm and the ODBII plug under the dash, but they are just the empty plugs with no pins in them. They came with a box of pins, though. If I just install the pins shown in the how to on here is that all I need?
    Jan 2006
    anyone?
    Oct 2005
    Try the "Bench Harness Tutorial.pdf"
    Its included with the latest version. Look under help.
    2014 VF SV LS3 Maloo.
    Jan 2006
    I read that, thats where I got the wiring info. My question is has anyone used just the plugs for the pcm and a odbII plug and wired up just the wires on the tutorial and make a working harness.
    Oct 2005
    Ive seen what I understand to be the working example from the tutorial on Paul's bench in the efilive workshop. So I imagine it works just fine.
    Jan 2006
    anyone know where the female 9 pin connectors go? All I have is the blue connector and the OBDII plug.
    Quote Originally Posted by minytrker
    I believe the female 9 pin D connector is used in lieu of the OBD-II connector; you can use either one, in your case you don't need the 9 pin D connector unless the blue OBD-II connector is missing any pins.
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 10:33 AM
  2. bench harness for ls2 and e38
    Last Post: March 29th, 2007, 12:39 PM
  3. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 02:13 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 08:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 02:25 AM
