i'm looking for a stock tune file for a 4l80e trans....would be using of a ls1 f body pcm (red/blue)
is there any sites like holden crazy?
The new tune repository is hosted on DropBox:EFILive DropBox Repository
Pick a 4L80E file with the same OS and segment swap it.
Awesome... Thanks
There's several 4L80E 12212156 files on the dropbox.
For T42s, you have very limited 4L80E options. The only vehicles that used them were the Express Vans from 08-10 (iirc), so you have to see if your TCM OS is the same as the one used by the Express (trucks and TBSS you're ok). Otherwise, you'll need to repin and run the 4L80E with a 4L60/70E trans segment.
I used a harness by Nelson performance. And repinned the 2 wires in the tcm connector. Your saying I need to keep searching around for the correct os numbers for the engine and trans. Or can I use new os for both Ecu and tcm and seg swap that and start from scratch. Like its a new vehicle. I
If you're running the 4L80E-on-4L60E harness, then +1 what Erik said, then it is necessary to keep the 4L60E segment.
