I want to switch to e85 eventually. I need to go from 83 to 120 lb injectors. I know I should tune the injectors in on 93 oct gas first. I have a decent tune on the 83 lb injectors now. I tried changing to the 120s and was have a hard time getting it to idle. I need help with the tune to get started. I have the injector data attached and need someone to tell me which tables I should put the data in. I tried but feel like I may have inserted some wrong. After the tables, what changes should I make to the 83 lb injector tune so I can start the 120 lb injector tune? I have a vac referenced return style fuel system. Thanks
GM_-_120lb.xls
