Results 1 to 10 of 13
Thread: Idle's beautifully ... if I hold throttle to desired idle ... what's going on?
    Oct 2003
    Default Idle's beautifully ... if I hold throttle to desired idle ... what's going on?
    I've been screwing around with the VE (lower area), timing, cracker and idle tables and, though the car will idle nicely all the way down to 700 RPMs (big cam, supercharger, LS7 Stroker, 2Bar MAP Sensor, COS5, SD mode), if I take my foot completely off the pedal, it will dip on down below 400-500 RPM's and die. This difficulty occurred after switching to the 411 PCM. The 2002 PCM solved my RPM over-rev issues and no longer kills the transmission, but just getting it to crank initially was an issue. I have non-sensical values I had to place for Injector flow rates to get it to crank and run. It runs strong now. But, this idle thing ...
    Any ideas what tables should I be massaging to overcome this?
    It won't settle out at the Desired Idle values I give it. What is going on?
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Post a log file and the tune file.
    Oct 2003
    Two Logs with different Parms and a tune I just uploaded where I increased Base Spark down low.
    Oct 2003
    Default Tune and 2 Scans
    Tune and 2 Scans
    In your log 0224 I see several things:
    - MAP is high at 86 kPa when TP is steady at 7.5%... what cam specs do you have (intdur/exhdur lsa adv)...?
    - MAP flucuates while throttle is steady, I don't see IAC steps, but it is fluctuating too much.
    What intake manifold do you have...? Do have any vacuum/air leaks...?
    Oct 2003
    The TP is 0% when the pedal is not pressed. Remember, I have to hold the throttle open slightly, for it to stay cranked. That's why you see a Throttle angle. I think it may even be off-idle.
    It idled the same place (800-900 RPMs, zero TP) on the 98 PCM and tune without cutting off.
    I don't think I have any vacuum leaks
    Also, remember, it wouldn't stay cranked the first time I loaded my tune after the PCM swap. I finally got it to stay cranked, but I can't take my foot off the accelerator pedal. Otherwise, it ran very strong.
    I have the LS7 Intake Manifold.
    Additional info: also, it cranks right up the first time, every time, cold or hot. But, I have to hold the throttle down slightly to maintain engine RPM at idle speed.
    Competition Cam:
    Gross Valve Lift: .623 .623
    Duration @ .006 Tappet Lift: 289 305
    Installed Specs:
    Duration @ .050 239 254
    Lobe Lift .367 .367
    Lobe Separation 115
    Thanks for your responses, joecar.
    Last edited by Black LS1 T/A; May 10th, 2017 at 11:07 PM. Reason: Cranking info added
    ok, we may have to go thru the idle tutorials...
    Oct 2003
    OK. The car is not inspected yet, so I can't drive ... just idle in my driveway.
    I'm getting a 10-day tag Monday, so I can take it to a tuner who says he is willing to tune with EFILive, and inspect the car so I can drive it. But, I need to time the 10-day tag where I can drive it a few days and still get it to him to iron out kinks before inspection. I was hoping I could get as much resolved as I can before I take it to him.
    Every tuner around here uses the other package. I don't know why it's become entrenched in the market here. :(
    Oct 2003
    I got it to idle without shutting off.
    Adjusted quite a few idle parameters, so I can't say what by itself may have done it.
    I also adjusted Injector Min Pulse width and Small Pulse adjust
    Post the before and after tunes, lets have a look.
  1. Desired Idle Airflow
    By ferocity02 in forum Gen III V8 Specific
    Last Post: March 26th, 2013, 12:06 PM
  2. Desired Idle
    Last Post: July 1st, 2010, 06:41 AM
  3. Rolling Desired Idle
    Last Post: October 12th, 2006, 05:18 AM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 11:07 AM
  5. LTFT desired values for idle, light throttle, WOT
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2006, 12:55 PM
