Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Idle's beautifully ... if I hold throttle to desired idle ... what's going on?
    Oct 2003
    Here is the Calibration file with the adjustments I made.
    (You have the "before" file in my post of the attachment before)
    1. It cranks right away.
    2. While cold, I have to hold the pedal down for it to stay in the idle area (about 800 to 875 RPM's).
    3. Once temperature is stabilized, it idles fine, in or out of gear. (It's like a threshold it reaches and it idles at zero TP, not as if it is really cold)
    4. Driving down the road, if I take my foot off the gas, around 30 MPH or so, it dips below idle point and I have to give it a little throttle.
    5. If I come to a stop at a light, as I ease off the pedal, it finds idle and holds.
    Old numbers with 422 Iron Block
    10.84 @ 124 MPH, 1.57 60\'
    549 RWHP / 757 RWTQ
    I'd rather be blown ... AND stroked!
    Now: 441 CID (Corevette 427) , ATI Procharger D-1SC Supercharger
    Looks like you may have to play with Throttle Follower and Throttle Cracker.
    Oct 2003
    Thanks, Joe. You're the best
    549 RWHP / 757 RWTQ
  1. Desired Idle Airflow
    By ferocity02 in forum Gen III V8 Specific
    Last Post: March 26th, 2013, 11:06 AM
  2. Desired Idle
    Last Post: July 1st, 2010, 05:41 AM
  3. Rolling Desired Idle
    Last Post: October 12th, 2006, 04:18 AM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 10:07 AM
  5. LTFT desired values for idle, light throttle, WOT
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2006, 11:55 AM
