Results 1 to 10 of 11
Thread: Having trouble getting factory E40 ECM file to open...
    Junior Member joshwho?'s Avatar
    Apr 2016
    Default Having trouble getting factory E40 ECM file to open...
    I have a "commercial" EFI Live V2 and I double checked that everything is current this morning. I've licensed or registered the V2, licensed the ecm to the V2, saved the stock file, but I can't figure out how to open the stock file to scale injector size or do anything else.
    I open the EFI Live "Scan and Tune" V8, click the "Tune" tab (F3) to open the "Tune Tool", go to "Open" and select the stock file and then click "Edit" (F5), THEN it says: "The version 8 calibration editor is not available yet. Until the V8 calibration editor is made available, you must use the V7.5 Tune Tool software to edit calibrations." ....so I click "Edit With EFILive V7.5" and it says in an Error window: "Can't exceute command: .\EFILive_Tune.exe Reason: File .\EFILive_Tune.exe not found."
    I have tried it with two laptops and have had the same results. I hope I am just missing something simple! Thank you ahead of time for the help!
    Ok, try these things:
    On the tune file, go rightclick->Open With and specify the V7 tunetool (you may have to browse to it under C:\Program Files (x86)\EFILive\V7.5\).
    Otherwise, go Start->All Programs->EFILive->V7.5->EFILive V7.5 Tune Tool and after it starts go File->Open and browse to the tune file and click Ok.
    Failing that, check that the V7 tunetool exists in this folder: C:\Program Files (x86)\EFILive\V7.5\
    if it doesn't then you have to re-install the V7 software.
    Apr 2016
    Awesome! Thank you! I can work on it now!
    It looks like you didnt have V7.5 installed so V8 couldn't open the V7.5 tune tool or there is a permissions issue on your machine.
    Are you able to actually view and edit the file now?
    Erik brings up a good point... you have to be logged in as Administrator when you instal the EFILive software, and also when you run it.
    Apr 2016
    I am able to view and edit the file now, I have done a little PE work and a little work on the timing table.
    The machine I use only has one "user" and it is the owner/administrator, but I suppose there could be somewhere that I need to give it permission. I honestly don't know the first place to start on that.
    I have logged, but when I play it back in "F6: Maps" it is just a red crosshair on a white graph with no map/table or values for where the crosshairs are. I have used standalones that let you essentially watch and tune the fuel map/table and spark map/table in real time and I understand that I'm not going to be doing that real time with what I have, but I figured I would be able to view that kind of stuff in a log.
    There is a LOT of stuff that I don't know about (and don't know WHERE they should be set) hiding in the factory ECM/PCM/TCM, so hopefully it's just something that I don't know about yet.
    I have to thank you all for posting, replying and generally adding knowledge to this forum! I have spent countless hours scrolling, searching, reading and lurking to learn and confuse myself and it is an incredible resource!
    Apr 2016
    Apr 2016
ID:	21069Click image for larger version.
    Post your log file(s).
    BTW: you can use your PC/laptop to grab a screenshot as follows:
    go SHIFT-PrtScr, then paste into some imaging program (e.g. Paint).
    There are programs to streamline this (and give you the feature of annotating with arrows/text), for example see getgreenshot.org
    Apr 2016
    Well I opened it earlier and there was nothing but a blank section with red crosshairs dancing around, but I watched it a few minutes ago and there were timing values, but then I clicked on the "show maximum" and "show minimum" arrows and I couldn't figure out how get get back to the ACTUAL values. Are the max and min arrows to show what are on the other maps like ECT, low octane, ect? Thanks again!
  1. i need a STOCK FACTORY file for an 08!
    By C Murda in forum Cummins 6.7L
    Last Post: March 4th, 2013, 02:32 AM
  2. Replies: 3
    Last Post: January 10th, 2012, 03:15 PM
  3. Needing Factory File
    By Picto in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 14th, 2011, 12:11 AM
  4. Chasing Factory File 24254909
    Last Post: July 4th, 2011, 10:54 PM
  5. VZ Factory File
    By Picto in forum Gen III V8 Specific
    Last Post: January 31st, 2011, 01:57 PM
