Results 1 to 8 of 8
Thread: Spark at 40?????
    May 2006
    Default Spark at 40?????
    Hey guys. When i crusing in 5th or 6th my spark gauge on the scan tool reads 40. When i get on it a bit it varies between 22-32. Does this sound right? Where in the EFI tuning softwhere do i change my timing?
    thx
    Oct 2004
    There are a few places:
    1) B5913 High Octane Spark Table
    2) B5914 Low Octane Spark Table
    I would expect that you are in the High Octane table, there is a scalar PID to see the balance between spark tables. Both of these table are used when the TP% is above B5916.
    3) B5932 Base Spark in Gear
    4) B5933 Base Spark in Park/Neutral
    These tables are used when the TP% is below B5916 and speed is below B5917.
    For an M6 trans only the in gear table is used.
    Andrew
    EFILive Crew
    May 2006
    How do i gauge what to set my tables at? Do i need a wideband for this? Also will the auto ve help out with this?
    Oct 2004
    Spark is the hardest thing to tune IMO. As for the wideband. My personal opinion is that a wideband should be mandatory for tuning!
    With spark you are basically looking to maximise the power at any given RPM vs. load point. You may be able to advance the timing a certain amount, but at some point you will get the onset of knock. At thins point you have gone too far :(
    When knock occurs you will need to determine if it is real (audible etc.) or false. You should also check the actual AFR (which is where you need the wideband) to make sure the mixture was rich enough for the load. Looking at the commanded AFR is not sufficient for this.
    If you are new to tuning the best thing might be to book some time on a load dyno and map the spark table, advancing and retarding till you get peak torque. This might also give you the opportunity to map the VE table, and get the optimum enrichment.
    Andrew
    EFILive Crew
    Jun 2005
    40* doesn't sound unreasonable at part throttle cruise.
    Jun 2005
    I get 40-41 when I'm off the gas all the time. As you give it gas, the timing will reduce. That's why the timing table looks like the side of a mountain.
    May 2006
    ok i got it now, the way i had my spark gauge setup, was to turn red at 40, so i thought it was bad. LOL i know im a newb. Anyhow. At WOT im around 28 or so. Sounds good, and i get 1.5 degrees of KR at like 2,000RPS so i think this is fictional KR. You guys think i would gain anything form adjusting my spark? Or do i really need to be on a dyno for that??
    Quote Originally Posted by killaz
    Post a pic of your log chart showing your KR and AFR.
  1. Take a look, please.. AFR, TCC, Spark
    By tatasta in forum Gen III V8 Specific
    Last Post: April 26th, 2009, 04:14 AM
  2. Under spark
    By twinki025 in forum Gen III V8 Specific
    Last Post: October 21st, 2007, 04:42 PM
  3. Base Spark and Spark Modifiers
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2007, 04:33 AM
  4. A few spark questions perhaps?
    Last Post: March 6th, 2007, 05:38 AM
  5. spark
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2006, 08:09 AM
