Results 1 to 10 of 19
Thread: E98 Vats PAtch
    Jan 2014
    Default E98 Vats PAtch
    Hello Guys,
    Do you have any news regarding the VATS delete on the E98 ecms?
    Thanks in Advance!
    I am sure we can do it but it has not been pursued because nobody had attempted a conversion, whenever anyone has something ready to try we can look at it.
    Jan 2014
    We are starting a diesel transplant and we have stuck in the VATS part. Could you look at it?
    I'd need to know what OS number is in the ECM you are tuning, perhaps if you can please Email the file you've read from the ECM to support@efilive.com with VATS removal as the title I can take a look.
    Jan 2014
    Hello,
    File's sent.
    Thanks in advance!
    Ok I have the file but I didn't realise this was going to be from an Opel, I assumed it would be a 2.8L Colorado. It's ok but it'll take a bit more investigation as the Opel programs we have not had a lot of experience with and they are quite different to the Colorado, I'll keep you updated on progress.
    Jan 2014
    Thank you very much for your effort! I am looking forward to hear from you soon!
    Jan 2014
    Hi Ross,
    Thank you for your support. I have tried the ECM on a vehicle and it started without any VATS programming! Although this operationg system requires a fuel pump ecu in the network. Could i send you a file from a car without fuel pump ecu in the network?
    Thanks!!
    Sure you can, but I did recently go over all the E98 Operating Systems and add the VATS patch in so everyone will have access to them shortly. But with your file if you can't wait for the next update then please Email it over to support.
    Jan 2014
    Thank you Ross,
    I am going to send you the file straight forward because the engine is on the chassis and we facing a problem now . Thank you in advance!
  1. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 12:01 PM
  2. Vats Patch
    By derkscustomcars in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2016, 05:42 AM
  3. E40 VATS Patch not working
    By SkinnyPedal in forum Gen IV V8 Specific
    Last Post: August 23rd, 2015, 12:42 PM
  4. what is vats patch and how do i use it
    By 400ss in forum Gen IV V8 Specific
    Last Post: July 5th, 2012, 08:10 PM
  5. E78 1.4 cruse vats patch?
    By MattS in forum E78, E83, E84 PFI ECM's
    Last Post: May 9th, 2012, 01:01 PM
