Results 1 to 4 of 4
Thread: Fueltech Ft600 coil wiring questions
    Nov 2015
    Default Fueltech Ft600 coil wiring questions
    Hi all, so I need some info. I'm going to be building a 509 cubic inch supercharged Big Block Chevy with coil on plug ignition and multiport fuel injection. I'm going to be starting with a Blueprint Engines long block and equipping it with a combo Whipple blower intake manifold and one of their 510R superchargers, fuel system is going to hopefully be completely alcohol compatible but definitely e85 compatible and the controller is gong to be a Fueltech Ft600 unit. I more or less understand how to wire the injectors but I don't know how to do the coil packs. I'm going to be using either LS2 or LS3 coils and was wondering if anyone knows how to wire the coils. I was also thinking of possibly using universal coils for the project but the problem I see with that is I wouldn't have any room in the engine bay for eight universal HEI coils. Anyway, thanks in advance.
    Sent from my LGL52VL using Tapatalk
    Doesn't the Fueltech have ignition coil drivers...?
    Nov 2015
    Yeah, I figured out the wiring not too long after I actually created this thread. But now idk if I'll need a cam synch sensor with me using a crank reluctor wheel with missing teeth and multiple coils or not... I emailed Fueltech earlier today and I'm waiting to hear back. And yes, the FT600 does have coil drivers.
  1. Coil near plug tuning vs distributor with contorl box questions
    By Powellbr in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2017, 11:58 AM
  2. LS7 coil for Gen III Tables
    By acric5 in forum Gen III V8 Specific
    Last Post: September 4th, 2012, 02:33 AM
  3. Which ECU for 6 Cylinder Coil On Plug and Custom O/S
    By Tydriver in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2010, 12:27 AM
  4. LS1 Coil per Cylinder Conversion - Are you ready?
    By S10Wildside in forum Vortec V6/V8 Specific
    Last Post: June 7th, 2009, 09:41 PM
  5. LS6 Coil Junction Connectors
    By rv6ejguy in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 01:40 PM
