Results 1 to 3 of 3
Thread: Help Needed! Manual Tune in OS 12659455, 3.6L
    Oct 2007
    Exclamation Help Needed! Manual Tune in OS 12659455, 3.6L
    Hey all,
    I'm converting an automatic 3.6L LFX for use in a standalone manual application. I have the vehicle running, but the idle is flaky and my best guess is because it doesn't have the auto trans hardware. I was using an outside source for the tune and I want to take it in my own hands with EFI Live. I need to do some MAF tuning and basic other cleanup. The controller I have is locked so I'm going to replace it and I'd like to load it up with a manual cal. version and start with that.
    I've checked on the Dropbox replacement for tunedepot and can only find E92 6.2L manual cals. The OS I've got is 12659455 and I think my new ECM will have the same.
    Does anyone have a stock tune for a 2013/14 Camaro 3.6L Manual?
    OS: 12659455
    If not, other ideas?
    Thanks for any help.
    Aaron
    Aaron Pfadt
    aaron@pfadt.com
    "If everything seems under control, you're just not going fast enough." - Mario Andretti
    Hey Aaron, I dont have one, you might have to just have someone bench flash the new ECM using GM SPS/Tis2Web to get the base OS setup with the 3.6/manual combo. Then you can tweak/update using EFILive to get the rest of the tuning squared away.
    Is the new ECM you're getting already loaded with a base OS, or is it factory fresh/blank? If it's factory fresh, you'll have to have it flashed with Tis2Web before you can use it.
    Jul 2003
    Can you post the tune?
  1. Replies: 16
    Last Post: October 22nd, 2017, 08:10 AM
  2. Stock 2011 2500 & 3500 files needed Auto and Manual
    By Move'n Up in forum Cummins 6.7L
    Last Post: May 17th, 2017, 11:10 AM
  3. Auto to manual (tune)
    By K3vin in forum Tips and tricks
    Last Post: November 22nd, 2016, 09:58 AM
  4. VE HSV6.0 manual tune
    By shane in forum E37, E38 & E67 PFI ECM's
    Last Post: December 7th, 2008, 03:34 AM
  5. E38 Manual tune, anyone?
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2008, 11:43 PM
