Results 1 to 7 of 7
Thread: File not supported wth?
    Oct 2010
    Default File not supported wth?
    I downloaded stock lbz tune of friends truck and went to open it and it comes up with this error. I habe the latest version, firmware and bootblock. Never seent his before. I know he was having issues with a hypertech and dealer reflashed his truck.
    Nov 2005
    What versions are you running? What versions is your friend running? Please list version numbers.
    It is possible your friend is running beta software only available for download from our forum.
    Cheers
    Cindy
    Sent from my iPad using Tapatalk
    Do you have the lastest version from here: 27604-April-2017-Beta-Release-2
    See what Cindy said above.
    Oct 2010
    He isn't running efilive, he had it reflashed at dealer cause he was having issues with his hypertech. I am just trying to get the tune since it's the newest one from GM for the LBZ.
    Version 2.07.007
    firmware 2.07.113
    build 8.2.5 build 316
    Nov 2005
    Quote Originally Posted by pavetim View Post
    Version 2.07.007
    firmware 2.07.113
    What about V7? You are reading with V8 Scan and Tune, but opening the tune file in V7 to edit - you need to be compatible across all softwares.
    The V7 software that matches your V8 installation is V7.5 Software: V7.5.9, Build 323
    Cheers
    Cindy
    Oct 2010
    I download tune off truck using V8 and when I go to edit tune it says can only edit with V7 so that opens up. but yes I checked my V7 and it's build 309 V 7.5.7. Maybe I'm just dumb lol but this whole V7 and V8 thing kind of sucks, can't wait till it's only V8. I'll update when I get home and see what happens.
    Oct 2010
    Updated my V7 and works now.
  1. file not supported
    By ironmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 29th, 2014, 10:53 AM
  2. File version not supported?
    By Zorganov in forum General (Diesel)
    Last Post: January 24th, 2014, 10:46 PM
  3. Script file not supported by current software version...
    By Straight 6 in forum Cummins 5.9L
    Last Post: June 27th, 2011, 03:50 PM
  4. Cadillac SRX 2011 Script file not supported
    By sportone in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 21st, 2011, 10:04 AM
  5. Can I get this file supported?
    By slows10 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: December 12th, 2010, 06:58 AM
