Results 1 to 8 of 8
Thread: Please verify process for this
    Oct 2010
    Default Please verify process for this
    I have been fighting this for awhile now. What is the proper way to add pids to model years and change the units. I know you can go into V8 and open Scan or you can do it in BBX but it never works for me. Like I went in today and changed the pid lineup for an LBZ and when I hooked up to truck it was a whole different pid lineup. And for the life of me I can't get the damn units to change.
    Moving to Flashscan V2...
    kb_article.php?ref=6659-YAHB-3781
    you specify your ECM in the blue area;
    you drag the pids from the yellow area to the green area and then do this:
    - on each pid you go rightclick->Properties,
    - checkmark Custom Pid Properties,
    - Quick select the units;
    - click Ok;
    - when done click Save (and give it a filename), then click Program and make sure it programs into your V2.
    More info: Setting-up-a-FSV2-from-scratch
    When logging on your FSV2 press the ENTER key to switch units for all pids (i.e. selects Custom Units).
    Oct 2010
    May have it now i'll see how it reacts when I hook up to truck. Whats the difference between doing pids from the BBX F5 and then Scan F2 button instead of doing them from the Scan F2 button on first screen?
    Nov 2005
    Save and Program are 2 different, independent functions. If you want to move a configuration to FlashScan/AutoCal you need to use Program.
    If you want to SAVE a configuration to your PC to use in the future, you need to use the save or save as function.
    Cindy
    Quote Originally Posted by pavetim View Post
    This configures the pids for V2 BBL (you have to click Program to write this config to V2).
    This configures the pids for the V8 scantool.
    Oct 2010
    Ok works good now. Thanks.
  1. verify calibration
    By roughneck427 in forum Allison 5 & 6 Speed
    Last Post: December 29th, 2011, 05:58 PM
  2. Verify Fuel injector numbers for 80's
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: October 15th, 2011, 05:08 PM
  3. Just want to verify what I belive (upgrading OS)
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 09:17 AM
  4. Please verify...
    Last Post: September 13th, 2006, 09:29 AM
  5. Calculated VSS (used to verify speedo calibration)
    By joecar in forum Tips and tricks
    Last Post: January 19th, 2006, 04:18 PM
