Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: E35B Digital MAF Scaling
    Oct 2010
    Default E35B Digital MAF Scaling
    Hi all,
    Would it be possible to get a cax file to modify the E35B Digital MAF tables?
    I'm looking to run a new style GM digital MAF with a higher a 12k HZ frequency range. I verified the E35B ECM will read up to 14818 Hz, but table B0205 currently ends at 8696Hz. If supplied a frequency above 9200Hz, the G/s reading falls to zero. So it appears to be running out of resolution in that table. The new style sensors should work fine if table values can be aligned.
    -K
    Dec 2013
    It may actually be a protection. There is likely some sort of threshold that when hit or crossed over it defaults to 0 g/s thinking the sensor has failed. That would be where you need to look. IMO
    Oct 2010
    I think it's just running off the end of the scale. But like you said, it would set an out of range code for certain. Reason I would like to adjust the scale and test it. Any help with finding that line would be greatly appreciated. Just bench testing at the moment, then I have a half dozen ECM's to upgrade.
    Dec 2013
    Ross, What was the deciding factor for EFI live to not map the axis for MAF digital {B0205}? Is it hardcoded somewhere? Similar to mapping counts in the Cummins stuff.
    Oct 2010
    Don't think he's stumbled onto this thread yet. Maybe we should PM him a link to it?
    Oct 2010
    Anyone have the A2L file for this OS to share?
    Quote Originally Posted by kidturbo View Post
    Yeah sorry I do tend to miss a lot of threads on here.
    Quote Originally Posted by SASDakota View Post
    I don't remember, it was 10 years ago
    I have a feeling we actually hard coded those axis values in to the software from whatever was in the stock files (I know that is not ideal), but maybe we hadn't sorted out the axis displays back then and it never got revisited.
    Can either of you do .cax files? I'm happy to tell you where the axis is for a given OS and you can add it in yourselves (I'll just post it up here). I am a bit reluctant to go and add this in to EFILive then regenerate the E35B .calz files again. I did do them back in Feb this year and it was a big pain to have to check over everything.
    Oct 2010
    I've added a cax file for MAP scaling to this OS before, so probably could handle it with a little reading.
    -K
    Let me know the OS and I'll save you the trouble (I'll PM the details).
    Oct 2010
    Since I all ready use this build with a MAP scaling mod, please let me know if any special tricks to using multiple cax files in same tune file.
    -K
  1. Maf scaling
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: December 10th, 2016, 05:24 AM
  2. Scaling MAF for Supercharged GM LS1
    By RamAir in forum Gen III V8 Specific
    Last Post: January 8th, 2013, 02:21 PM
  3. 2012 CTSV Maf scaling, open loop issues.
    By ditosmotors in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2012, 02:37 PM
  4. Why reduce MAF scaling values on a basically stock E38?
    Last Post: June 24th, 2011, 11:44 AM
  5. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
